Ever since installing Inventor 2021, I keep having graphics issues where typically the Extrude and Measure Windows pop up when they shouldn't, and once up they remain (although not active). The only way to remove them is to either activate measure or extrude, and then cancel. Another quirk is when I create a sketch, on exiting it instantly becomes invisible. I then need to turn it on to allow me to perform an Extrude etc on it.
Any ideas what the problem is? I've already un-installed and re-installed, but made no difference. Also I've updated the graphics driver (Quadro M1000M).
Thanks for any help,
Chris.
Chris.
Thanks your update, @cjones. We tracked INVGEN-38968 and need more investigation about the root cause still. Will let you know once there is any update. Thanks for your patience.
