Inventor Forum
Vault log in and usage
1 REPLY 1
186 Views, 1 Reply
How do I create an account with Vault. I have all 2018 products; yet, it states it can't find my data management service. I would like to create an account and use multiple computers to change files and update them on multiple computers at the same time.
1 REPLY 1
jhackney1972
A Vault configuration consist of a central Data Management Server that contains a Microsoft SQL database and a filestore.  Once this is established, other workstations running applications, that support the Vault such as Inventor, AutoCAD and the Vault Client, log into the Data Management Server.  Once this is done files can be checked in and out of the Vault as well as many other file services.  A simple layout of this configuration can be found in the PDF attachment.  Most of the time the Data Management Server is located on a separate computer, as indicated in the diagram, but on certain circumstances, it can be located on a workstation.
If this is already done, once you create user accounts, via the Vault Client when logged in as an administrator, you should be able to log into the Data Management Server from any workstation as long as it is on the same sub-net.  In other words, if you can ping the Data Management Server, you can log into it.  If you still cannot log into the Data Management Server, there could be other problems in the setup of Internet Information Services which the communication depends on.
I do not know you situation and at what step in the configuration you are presently at so I can specifically comment on your issue.  I have only presented an overview of what you have to configure to get started.
John Hackney, Retired
