Inventor Forum
vault and revision table inventor 2014
9 REPLIES 9
Message 1 of 10
m_hermann
699 Views, 9 Replies
Hello all,
i use the vault revision table. with new documents everything is o.k. I did export the revision table and import it to a Inventor 2012- made document (which I saved then in 2014).
I want to put the vault revision table on these document but I got the error: a property doesn't correspondent
to a clumn header.
The Revision style is ok. All columns are korrekt (in 2014 new documents everything is ok).
There are 2 properties in vault revision table which i defined as -create it if dosn't exist- in inventor. So if i make an property update in
vault they might be create in Inventor.
What is the problem?
In screenshot you find the error (but in german :))
9 REPLIES 9
Message 2 of 10
m_hermann
in reply to: m_hermann
in short:
How do I get the Vault 2014 Revision Table in an Inventor 2012 document (first i migrate it to Inventor 2014) if some revision table
properties doesn't exist in this document?
Message 3 of 10
cbenner
Message 4 of 10
m_hermann
in reply to: cbenner
no, update property dos not create the properties
Message 5 of 10
m_hermann
the user defined Properties from vault are created in Inventor iProperties with the correct entries, that works.
Message 6 of 10
m_hermann
see next answer
Message 7 of 10
cbenner
Message 8 of 10
m_hermann
yes
Message 9 of 10
m_hermann
did you see the screenshots? yo'll find the error
Message 10 of 10
m_hermann
I have the solution from Autodesk Kevin Jaufmann-Ludwig.
In the 'old' documets are revisiontable- styles which must be updated with the properties from the 'new' revision table.
That works.
Many thanks
Technology Administrators
