Inventor Forum
Upgrade Autodesk inventor 2012 to 2014
5 REPLIES 5
537 Views, 5 Replies
Does Autodesk Inventor 2014 handle upgrade of lower versions?
5 REPLIES 5
Are you asking if you can upgrade the program, or have to uninstall and install a new one?
Or are you asking if it handles old files?
mcgyvr
yes new versions of Inventor will prompt you to "migrate" files created in older versions.
If thats what you are asking
blair
in reply to: mcgyvr
Once you "Migrate" your files to the newer version, you won't be able to open them in the older version. The only way that you will be able to work with them will be to export them out of the newer version into a neutral format such as ISGES or STEP and then import them into your old version of Inventor. This will remove all the feature data from the model tree for all the IPT files and they will become "dumb" solids.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
in reply to: blair
Hi all,
I want to uninstall lower version and keep only higher version.
I checked this scenario and find higher version doesnot support upgrade of lower version instead both coexist.
cid:image001.png@01CFA60E.242919A0
We do not want lower version to exist on machine. Please respond ASAP.
Another query : does autodesk require compulsory REBOOT after uninstallation/
Can we manually uninstall lower version and then install higher version without REBOOT in between.
You will have to uninstall lower versions.
It reboots for the sake of the registry database. It is prone to make errors during an installation if you don't reboot.
Technology Administrators
