Hello all,
i use the vault revision table. with new documents everything is o.k. I did export the revision table and import it to a Inventor 2012- made document (which I saved then in 2014).
I want to put the vault revision table on these document but I got the error: a property doesn't correspondent
to a clumn header.
The Revision style is ok. All columns are korrekt (in 2014 new documents everything is ok).
There are 2 properties in vault revision table which i defined as -create it if dosn't exist- in inventor. So if i make an property update in
vault they might be create in Inventor.
What is the problem?
In screenshot you find the error (but in german :))
Solved by m_hermann. Go to Solution.
in short:
How do I get the Vault 2014 Revision Table in an Inventor 2012 document (first i migrate it to Inventor 2014) if some revision table
properties doesn't exist in this document?
Have youused "Update Properties" on the drawing? Does this not create the custom properties from the Vault?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
the user defined Properties from vault are created in Inventor iProperties with the correct entries, that works.
So, you have the UDP's, but you cannot get them to populate the Vault Revision table?
Chris Benner
I have the solution from Autodesk Kevin Jaufmann-Ludwig.
In the 'old' documets are revisiontable- styles which must be updated with the properties from the 'new' revision table.
That works.
Many thanks
