Using Positional representation in inventor studio error.
b_ruijter
Message 1 of 14
b_ruijter
I tried to use Pos Reps to make a simple animation in inventor studio in Inventor professional 2019.
The pos reps in the main assembly controlled pos reps in sub-assemblies. Is there a reason that this does not work? I can't seem to get the animation working?
If i manually click, Position1, Position2, Position3, Position4 in the normal modeling environment. Everything looks fine. But when i use these pos reps in an animation, nothing happens? or a bit movement?
Does anybody know what I’m doing wrong?
Hope anybody can help...
Replies (13)
Message 2 of 14
Mark.Lancaster
@b_ruijter
Here's my advice on this subject matter...
Animating positional reps work the best when the positional rep is solely at the top of the assembly.  When positional reps start driving other positional reps (buried in the main assembly), you may have to make those (buried) positional reps flexible.   In the end positional reps that are buried just may not work at all.   Remember Inventor studio hasn't really changed in many releases.
Mark Lancaster
Message 3 of 14
b_ruijter
Realy???
Thanks for the reply, i'll let you know how it will turn out.
Not quite sure how i do this with the flexible. You mean, the sub-assembly's flexible, and constrain it in the toplevel assembly?
Message 4 of 14
johnsonshiue
Hi! If you can share an example, I can help take a look to understand the behavior better. There are indeed some confusing behaviors in flexible and positional representation.
Many thanks!
Software Test Engineer
Message 5 of 14
kelly.young
Autodesk Support
Autodesk Support
Hello @b_ruijter I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
Here are a few good resources going over Flexible Assemblies and how to set the sub-assemblies to flexible:
Help: About Flexible assemblies
Cadline: Inventor: Quick Tip - Flexible Assemblies
If you want to attach you assembly with Pack & Go as .zip for others to inspect that would be helpful!
Please select the Accept as Solution button if a post solves your issue or answers your question.
Message 6 of 14
b_ruijter
In the original file there is more. But this is the problem in a nutshell. I made for pos reps, Activate them shows the desired motion. As soon as i use Inventor studio (i made a Animation1 wher i animate the pos reps, so you can check) something is moving. But inventor forgets half the motions.
Is this a bug in inventor? Or am i doing someting wrong?
Message 7 of 14
Markcanon2000
Hi , Is there any more information on this, im trying to make an animation with 15 Pos reps and many sub assemblied and the first works correcty ones but then non of the others do.
Message 8 of 14
johnsonshiue
Hi! This could be a bug or something isn't set up correctly in the PosRep. It is hard to comment further without seeing the files. Please share the Inventor files (in zip) you are working on here or send it to me ([email protected]) directly. I would like to understand the behavior better.
Many thanks!
Message 9 of 14
Markcanon2000
Hi
Please see link to the file.
https://we.tl/t-ksiZLme4qy
At one point i managed to get the panel door animated , tried to do the others , now non of them work.
Kind Regards,
Mark
Message 10 of 14
Markcanon2000
Hi I managed to get the panel door working too, did you try any of the other pos reps?Panel doors
Message 11 of 14
Markcanon2000
I also got a grip movementGrip
Message 12 of 14
Markcanon2000
so i know it can do it if ive done my pos reps correctly i think its just a matter of getting the work flow correct.
Any advice on workflow?
Message 13 of 14
johnsonshiue
Hi! If possible, please share the download link. The old one has expired.
Many thanks!
Message 14 of 14
Markcanon2000
Hi Please see Below.
https://we.tl/t-rSamBgDQDV.
Ive managed to get the panel doors open.
https://we.tl/t-JuTbvFsWAS
And the side grips
https://we.tl/t-K5p01F0JUy
Thank you
Mark
