unresponsive adaptive parts
- Mute
- Permalink
- Report
I use Inventor 2023 but the problem I am having goes back to the 2018 version. When I route a hydraulic hose in an assembly the hose part number is adaptive and I can drive various constraints in the assembly and the hose will follow along as expected. However, I can make the exact same assembly with the same constraints and route another hose and although it says it is adaptive I cannot drive the assembly constraints any longer.
I do the hose routing the "old school" way using work axes, work planes and work points. It seems the problem is always related to the various work axes. If I suppress those constraints the assembly can be moved but the hose obviously does not go along with it. Sometimes if I leave the assembly and come back to it later, it will work, but not all the time. It is very frustrating and I have spent countless hours trying to figure it out to no avail.
Does anyone have any suggestions? Thank you.
