Inventor Forum
uninstall tool: uninstall is greyed out
5 REPLIES 5
stefaan.boel
1890 Views, 5 Replies
I'm instructing our userbase to remove older versions of their PC using the uninstall tool.
A user reported back to me that she can not uninstall, as the button is greyed out. What's the root cause of it? Solution?
Tags (1)
5 REPLIES 5
SBix26
in reply to: stefaan.boel
I don't know what causes it to be disabled, but I think the quickest way forward would be to simply re-boot the computer, then try again.  If that doesn't do it, perhaps it is a permissions issue, that the user does not have administrator privileges.
Sam B
Inventor Pro 2021.2.1 | Windows 10 Home 2004
LinkedIn
johnsonshiue
Hi! I have not seen this behavior before either. Like Sam mentioned, it is probably UAC or User Profile related. What about uninstalling from Control Panel -> Programs and Features?
Maybe you need to run Autodesk Uninstall Tool as an Admin.
Many thanks!
Software Test Engineer
stefaan.boel
in reply to: SBix26
Well, indeed a reboot did the trick here.
User just reported back to me. Thanks for the tip!
b.mccarthy
The issue still persists.
I have several 2023 versions installed (Inventor, Mechanical, etc.), which do not display:
Neither a reboot or "Run As Admin.." affects the list.
johnsonshiue
Hi! Starting from 2022 product line, the install process has been changed. The Uninstall Tool no longer supports newer products.
Many thanks!
