- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm having a hard time understanding and controlling Hatches in Inventor drawings.
I've read a few posts on it (there's not much I could find away) on how inventor adds angles to come up with it's own rotation.
I'm using a lot of wood in my assemblies, and I have a custom Plywood hatch pattern by material set to 0 deg in both styles library and in the .pat file as well. On top of that I've made another plywood hatch pattern set at 90deg (inventor style set at 0 deg plus .pat file rotated to 90deg.)
What I don't understand is why inventor keeps on rotating the hatches into some weird angles all the time. Plus, once I manually fix them to either 0 or 90 deg. any minor revision to the view or any associated detail, it reverts back to it's crazy strange rotation. Most of the plywood/wood parts I model are horizontally or vertically - 0 or 90 deg - so why all those unusual angles?
All I really want is to have all my wood hatches (by material) come out at 0 deg., manually change ones I need to be at 90 and NOT have inventor change them on me each time I make a minor tweak.
Is there a way to make this work? I'm wasting too much time fixing each hatch, every time, all the time.
