I'm having a hard time understanding and controlling Hatches in Inventor drawings.
I've read a few posts on it (there's not much I could find away) on how inventor adds angles to come up with it's own rotation.
I'm using a lot of wood in my assemblies, and I have a custom Plywood hatch pattern by material set to 0 deg in both styles library and in the .pat file as well. On top of that I've made another plywood hatch pattern set at 90deg (inventor style set at 0 deg plus .pat file rotated to 90deg.)
What I don't understand is why inventor keeps on rotating the hatches into some weird angles all the time. Plus, once I manually fix them to either 0 or 90 deg. any minor revision to the view or any associated detail, it reverts back to it's crazy strange rotation. Most of the plywood/wood parts I model are horizontally or vertically - 0 or 90 deg - so why all those unusual angles?
All I really want is to have all my wood hatches (by material) come out at 0 deg., manually change ones I need to be at 90 and NOT have inventor change them on me each time I make a minor tweak.
Is there a way to make this work? I'm wasting too much time fixing each hatch, every time, all the time.
Solved by PaulMunford. Go to Solution.
Hi! Here is some documentation about the custom hatch behavior. The added angle in Inventor is to support AutoCAD Hatch Pattern.
Many thanks!
I have this same problem! This needs to be fixed. I want all my hatch angles to come in at 0 degrees (or 90). Then I have to modify one or two. As it is, I spend a good portion of my time changing the hatch angle so my plywood doesn't look goofy. I was hoping there was some way to globally change the hatch angles withing a drawing using ilogic, but haven't found anything...
Here is a way to do so.
Firstly, please go to edit hatch pattern dialog and select others in the dropdown list, export any of wood you'd like to use, and then open it, modify the value for the angle and re-import back as customized one. Try to define the customized one as your material default and you will get what you want.
I will upload a video for you.
Hope it helps!
Hi @Xun.Zhang,
Thanks very much for your hard work - but i'm afraid that your proposed solution doesn't quite address the problem!
I believe that the issue isn't the default hatch angle. I believe that the issue is Inventor's ability to automatically rotate hatches on separate parts so that they are always at a unique angle to the parts around them.
This feature is a great bit of automation that helps us comply with drawing standards. This is a specific case where we don't need the help 😉
I tested your proposes technique with an assembly, here is a screen shot:
(I numbered the order in which I inserted the parts into the assembly).
I believe that the request is to be able to turn off the Automatic rotation behaviour, either hatch style by hatch style, or failing that View by view, or failing that style by style.
Here is an illustration of the result.
Is that helpful?
Paul
Hmmm,
I may have fixed it with suggestions from this post:
http://beinginventive.typepad.com/being-inventive/2011/07/fix-hatch-angle-in-section-view.html
and this one:
https://forums.autodesk.com/t5/inventor-forum/hatch-patterns-explained/td-p/6243656
I set the allowable hatch angles to 0 and it seemed to work:
Styles and standards > Current standard > General > Preset values > Section Hatch Angles > Delete all values apart from 0.00
I posted on this a while back.
In the UK we need adjacent parts to be 45degs but can be different scales etc.
Inventor randomly changes the angles!
So we - myself and school kids I teach - have to manually edit each hatch pattern !
https://forums.autodesk.com/t5/inventor-forum/hatch-pattern-in-an-assembly-not-45-degs/td-p/5501427
