Inventor Forum
unable to delete image from title block
11 REPLIES 11
Message 1 of 12
2011 Views, 11 Replies
I've recently created a new title block and have inserted a logo onto the title block. I've decided I don't like the logo and would like to use a different one. I've deleted the original image , but every time I insert the title block the image reappears. Id really like to avoid recreating the title block but im not having much luck.
so far ive tried :
Save copy as  - didnt work
Tools , links , break link - didnt work.
Does anybody have any suggestions .
Labels (1)
11 REPLIES 11
Message 2 of 12
NigelHay
If I open one of our drawing borders then R.Click on the border in the browser →Edit Definition, I can delete our logo & it saves OK.
Message 3 of 12
in reply to: NigelHay
I've tried this also . I can delete the images temporarily but if i edit definition and then click yes to save , the images re-appear, appreciate the response though.
Message 4 of 12
Found the solution ,
when deleting the image you must use the lower delete option as shown below in green not the one shown in red.
Message 5 of 12
chris13
Did you delete it from your template file??
Message 6 of 12
chris13
Message 7 of 12
in reply to: chris13
Yes. For some reason the top delete function doesn't do the same as the bottom one.
Message 8 of 12
JoyceZhou
Hi rosshall93, could you inform which release build are you using?
I didn't see the issue on R2021. And I have tried to use the Delete command in the context menu above Zoom, it works.
Joyce
Joyce-Jinghua Zhou
Inventor QA Engineer
Message 9 of 12
Cris-Ideas
in reply to: JoyceZhou
@JoyceZhou
Oh the issue is here.
I have reported this for 2021.
Only delete from RMB context menu works.
Del key does not.
Cris.
Cris,
https://simply.engineering
Message 10 of 12
JoyceZhou
There might be some difference between our workflows, could you please share a video for your workflow to see the 2 Delete cmds?
And i'm using 2021.289R2, what's your build number?
Joyce-Jinghua Zhou
Message 11 of 12
Cris-Ideas
@JoyceZhou
see here:
https://forums.autodesk.com/t5/inventor-forum/linetypes-why-dots-are-arctually-lines-how-to-remove-l...
And just play with it. I do not have a video of that particular bug.
But if this behaviour was not there I would not brig it up.
Cris.
Cris,
Message 12 of 12
tobias
In 2021 there is only one delete in the RMB menu. I could delete the image but it reappeared again after saving. The trick, which worked for me, is first move (drag) the image and then delete with rmb menu option.
Tobias
The Netherlands
Inventor Pro 2025, Vault Pro 2025, AutoCad Electrical 2025.
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
