Hello guys,
Do you happen to know a way to install multiple Inventors on the same machine? Any kind of suggestion is appreciated.
Solved by Neil_Cross. Go to Solution.
Only one version of Inventor or Inventor Pro can be installed on a machine. However Inventor Pro and Inventor HSM can reside on the same machine.
Update: Reading your requirements again.. Are you asking about install different Inventor year release version or something else? I now read your posting two different ways..
Mark Lancaster
& Autodesk Services MarketPlace Provider
You can only install one at a time... i.e. you can't have both 2018 and 2019 installing at the exact same time. But you can install 2018, let it finish, then install 2019.
There's no limit on how many can be on at once, here I have around 10 versions on one machine:
Thanks @Neil_Cross
