Has anybody else experienced very 'twitchy' drop down menu's when right clicking a component/feature from the model tree? Whenever I right click ANYTHING, if i move my mouse even minutely straight after clicking, Inventor automatically selects whichever option my mouse is hovering over. So quite often a component might become invisible or Inventor might select 'create note'. It has only happened since upgrading to 2018 and occurs every singly time I use the software. I have checked my autodesk desktop app and all available updates are installed. So I wondered in that case if there is maybe an option within application options to stop this from happening?
Solved by johnsonshiue. Go to Solution.
Solved by -niels-. Go to Solution.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Hi Robert,
Yes, indeed this is the right-click Marking Menu issue. The behavior should be fixed in the coming 2018.2 Update. If you cannot wait for the fix, you could consider turning off Marking Menu (go to View -> User Interface -> uncheck Marking Menu).
Many thanks!
Thanks both, didn't realise it was a common issue but glad it isn't just me experiencing this. Will keep an eye out for the update. Much appreciated
