Inventor Forum
Tutorial Gallery error Autodesk Inventor 2020
33 REPLIES 33
Message 1 of 34
4654 Views, 33 Replies
Hi there,
I am getting the following error when I try to open the Autodesk Inventor 2020
tutorial gallery.
Cannot GET /guided-tutorial-plugin/v3/gallery
I have just installed Autodesk Inventor.
33 REPLIES 33
Message 2 of 34
j.palmeL29YX
Have you installed the 2020.3 Update?
Jürgen Palme
Message 3 of 34
in reply to: j.palmeL29YX
Yes, I have.
Message 4 of 34
After I installed it, the Tutorial Gallery no longer shows up in Autodesk, I attached an image. Capture.PNG
Message 5 of 34
j.palmeL29YX
Maybe it is only hidden? Pick the drop down arrow ... (see attached image).
HTH
Jürgen Palme
Message 6 of 34
mdavis22569
What happens if you unplug from the Internet and start using them?
Also, make sure you have access to the following:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
(Yes it says AutoCAD but it could be you're blocked to getting access)
Mike Davis
Message 7 of 34
johnsonshiue
Hi! Go to Tools -> Add-Ins -> make sure "Interactive Tutorial" Add-In is loaded.
Many thanks!
Software Test Engineer
Message 8 of 34
I tried that and it didn't work, here is what happened:
Message 9 of 34
in reply to: mdavis22569
After I updated to 2020.3 version, I can no longer find the tutorial gallery in the top bar. I tried unplugging the internet and nothing changed
Here is a screenshot:
Message 10 of 34
in reply to: johnsonshiue
The tutorial gallery is loaded, but it does not show up in the top bar.
Message 11 of 34
Hi everyone,
Originially I was having problems with the Tutorial Gallery so I installed the 2020.3 update.
Now when I open inventor, the tutorial gallery is missing from the top bar.
I have tried several methods to fix this including unplugging the internet, checking add-ins to see if tutorial gallery is loaded, and none of these methods have worked.
I would appreciate any help please and thank you!
Message 12 of 34
mdavis22569
Did you change / modify yours?
I don't have the User etc under my get started like you're showing
it's like it didn't fully install. I would do a reinstall with the Inventor Reset Utility ... get it back to Out of the Box look
Mike Davis
Message 13 of 34
After using Inventor Reset Utility this is what happens:
Tutorial Gallery is still missing.
Message 14 of 34
mdavis22569
We're a tad close ...
Do you know if the MSI has been installed?
I would review this now
https://forums.autodesk.com/t5/inventor-forum/autodesk-desktop-connect-and-guided-tutorial-plugin/td...
Mike Davis
Message 15 of 34
Yes both of those MSI's are installed, yet it is still not showing up.
Message 16 of 34
mdavis22569
Addin loaded?
Mike Davis
Message 17 of 34
Yes addins are loaded.
When I doubled clicked on each of the MSI's, a message popped up that said
Stopping LWS, and then it automatically closed.
Message 18 of 34
DannyHubbard
Can you try reinstalling the Tutorial Plugin and the Connected Desktop service using the AutodeskDesktopConnect.msi and AutodeskGuidedTutorialPlugin.msi  as mentioned in https://forums.autodesk.com/t5/inventor-forum/autodesk-desktop-connect-and-guided-tutorial-plugin/m-...
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
Message 19 of 34
I am still getting the error : access to desktop.connect denied    at startup.
Message 20 of 34
in reply to: DannyHubbard
I seem to have identified the issue:
I am getting the following error after unchecking and checking loaded and automatic on adding.
I have desktop connector installed, but I am getting this error. Is there a way to reinstall or fix desktop connect?
