- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm working with Autodesk Inventor 2024 using a Samsung M7 4K monitor at a resolution of 3840 x 2160 pixels, changing the text size to 200%.
I have changed the application's DPI settings and the workspace, it looks small but sharp.
I have two problems:
1.- When I open the program, the window does not maximize completely. As seen in the attached image, two logos appear.
When I minimize and then maximize the program again, the screen appears cut off (see attached image).
2.- In the 2D drawing section, the commands are not fully visible.
Please, if anyone has experienced the same issue, could you comment on how you resolved it?
Thank you very much.
