Hi Inventor community,
I have this piece in which I have a depression on the inside. I want to model a separate piece that will perfectly fit into this depression/cavity but I am having trouble achieving the exact measurements to match this. Is there an easy way I can achieve this? IPT file attached below.
For context the reason why I am not modelling it as one piece is because I plan to print these parts using two different plastics on a 3D printer.
Thanks for your help!
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
This is just an example with what you posted, you'll have to apply the method in the way that generates the shape you actually need.
I used the sketch that was present and this might not be the most optimal method, but hopefully you'll get some inspiration from it.
Hope this helps.
Niels van der Veer
The Netherlands
Hi! This is fairly easy to do using Surface Modeling techniques. It is better to reuse what is already available than to create new geometry from scratch. You just need to get those faces and then sculpt it to a new solid body.
Many thanks!
