We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
Trouble creating flat pattern
Message 1 of 50
I've tried creating a flat pattern from a curved panel but I'm not having any luck. I've tried creating the part different ways, so I'm not sure what I'm missing from this process. Does anyone have any suggestions? Any help would be grateful.
I'm using Inventor 2015.
Replies (49)
Message 21 of 50
Ok i will ... just a second to download all packs 😛 ..
thnx a lot ..
Sam
Message 22 of 50
thats ok ?
Message 23 of 50
JDMather
Now draw the two object lines overtop of the construction lines on the left side.
Dimension as shown.
Draw the same two lines on the right side, but do not dimension.
Instead of dimension, add Equal (=) constraints to the lines on the left.  (you might have to use the Right Mouse Button - Select Other to get the object lines rather than the construction lines.
Message 24 of 50
Ok .. i think its ok ...
rgs,
Sam
Message 25 of 50
JDMather
You are missing obvious dimensions?
Message 26 of 50
Thats ok ? or .. i missed something ..
rgs,
Sam
Message 27 of 50
JDMather
Create a vertical construction centerline.
Sketch a circle as shown.
You will have to right click to enter the dimension as a Radius of 616.First Arc.png
Message 28 of 50
thats ok ? 😛
Message 29 of 50
JDMather
What did you do?
Notice that the sketch changed color indicating that it is no longer constrained?
Start over.
(and the instruction was to dimension as a radius - not a diameter)
Message 30 of 50
ok ... i f**** something before ...
i think thats ok ?
Message 31 of 50
JDMather
Nope, all wrong - and obvious.
Attach your *.ipt file here.
Message 32 of 50
rgs,
Sam
Message 33 of 50
JDMather
It might be best if I create a video.
Supper time right now - back in about an hour.
Message 34 of 50
No problem ... thnx a lot for helping me out ...
Im going in bed .. here is 00:00 oclock, have job at 6 AM 🙂  ... so i will be online tomorrow all day ...
thank you one more time ...
And one question ?
Developing a Hardware .... etc ... is your book ? 🙂
Nice one btw if it is yours  ...
rgs,
Sam
Message 35 of 50
JDMather
Do not go beyond the steps in this video (turn on your sound).
There are some critically important considerations that I must get information from you before proceeding to next step.
Message 36 of 50
I think its ok ... 3 dimensions needed... rgs, Sam http://imageshack.com/a/img922/9977/pMlTw9.jpg
Message 37 of 50
And thnx for a very good video ...
Message 38 of 50
And btw this is the form from acad ... have to be like this one ... but i have to cut on the bottom for plates ... ( i will upload *.dwg somewhere because something wrong with attach files here ... )
Message 39 of 50
JDMather
I don't go to third party image sites.
Attach your *.ipt file here and end all doubt.
Message 40 of 50
sorry didnt know that...
rgs,
Sam
