Trouble creating flat pattern
Message 1 of 50
I've tried creating a flat pattern from a curved panel but I'm not having any luck. I've tried creating the part different ways, so I'm not sure what I'm missing from this process. Does anyone have any suggestions? Any help would be grateful.
I'm using Inventor 2015.
Replies (49)
Message 2 of 50
CCarreiras
Hi!
First, the thickness value as to be the same as the thickness in sheet metal rule to be able to flat.
Anyway, the flat pattern can't solve with that geometry, so i maded a new approach. Check it!
CCarreiras
Message 3 of 50
That works perfect.
So you created a contour flange based on the geometry of the original model, but how do you apply the unfold tool?
Message 4 of 50
CCarreiras
Click Unfold
Select the lower "tickness face" as stationary face
select "Add All Bends"
and that's it
Next split the faces
Do the cuts
and Refold (in the browse tree, hover the mouse arrow in Unfold, right mouse button and choose "Refold").
CCarreiras
Message 5 of 50
Ok, got it. Thanks again Carlos.
Message 6 of 50
JDMather
I noticed that it looked to me like maybe you were doing too much work.
I used 2 simple sketches - is this what you are after?
Message 7 of 50
Yes, this is a much simplier way to approach it. Thanks for breaking it down more efficiently.
Message 8 of 50
JDMather
Make sure that your sketches report Fully Constrained in lower right corner of the screen when editing.
Message 9 of 50
Okay, will do. Thanks
Message 10 of 50
Hello to all ...
i will borrow this topic for my problem 🙂 ...
I cant get flat pattern of this file, i will attach it, so if someone can explain me what am i doing wrong ? ...
Thnx a lot, because i have a lot of those parts so i have to repair them all 🙂
Sam
Message 11 of 50
mdavis22569
it's a derived part ....
do have the original ipt that it's derived from?
Mike Davis
Message 12 of 50
This is pack n go ... so you will see ... , and i have to flat pattern all of it 🙂
What is the problem here ? ... only one corner make flat pattern the other not ..
thnx for helping me out 🙂
regards,
Sam
Message 13 of 50
So what do you think is the fastest way for flat pattern ?
Sam ...
thnx 🙂
Message 14 of 50
mdavis22569
why is it derived ...
... you could make this quickly with a contour  ...
Mike Davis
Message 15 of 50
maybe because it is from multibody or something ? ... i think is the best way ... that u said ... new one ... with a contour ...
or .. ? 😛
Message 16 of 50
mdavis22569
quick ref' you need to dimension it fully, to what it should be...
Mike Davis
Message 17 of 50
Thnx a lot ...
have a nice day / night 😛
cheers from Slovenia 😛
,Sam
Message 18 of 50
JDMather
@Anonymous wrote:
Hello to all ...
i will borrow this topic for my problem 🙂 .......
You should have started a new thread and then add link to this thread if it was relevant.
iProperties seems to indicate that you have not installed Service Packs.
The 7A dist.ipt master file was all that was really needed to diagnose the problem.
Your geometry is missing nearly all relevant constraints - especially Tangents, Vertical....
You did wayyyy too much work - you do not need double lines for sheet metal parts - only the one side profile.
Your geometry is not dimensioned.
Your geometry is not anchored to the Origin Center Point.
Do you want to learn how to do this design correctly?
Message 19 of 50
huh a lot of problems i see 😄 ...
Yes if you can help me how to easy make this one of course 🙂
thnx for fast help ...
regards,
Sam
Message 20 of 50
JDMather
Step 1. Install the Service Packs and Updates for your version of Inventor.
Step 2.  Your dimensions (or lack of) do not make logical sense.
Start a new part file.
Turn on the Visibility of the Origin Center Point.
Create a rectangle above the origin.
Add a Coincident constraint between the midpoint of the bottom horizontal line of the rectangle and the origin.
Dimension the rectangle as shown in image below.
Change the lines to Construction linetype.
Now we have established the width and height of your design for this letter A.
Attach your file here for next instruction.
