Trouble creating flat pattern
Nicht anwendbar
2.571Aufrufe
49Antworten
Nachricht 1 von 50
Nicht anwendbar
I've tried creating a flat pattern from a curved panel but I'm not having any luck. I've tried creating the part different ways, so I'm not sure what I'm missing from this process. Does anyone have any suggestions? Any help would be grateful.
I'm using Inventor 2015.
0 „Gefällt mir“-Angaben
Akzeptierte Lösungen (1)
2.572Aufrufe
49Antworten
Antworten (49)
Nachricht 21 von 50
Nicht anwendbar
Ok i will ... just a second to download all packs 😛 ..
thnx a lot ..
Sam
Nachricht 22 von 50
Nicht anwendbar
thats ok ?
Nachricht 23 von 50
JDMather
Now draw the two object lines overtop of the construction lines on the left side.
Dimension as shown.
Draw the same two lines on the right side, but do not dimension.
Instead of dimension, add Equal (=) constraints to the lines on the left.  (you might have to use the Right Mouse Button - Select Other to get the object lines rather than the construction lines.
Nachricht 24 von 50
Nicht anwendbar
Ok .. i think its ok ...
rgs,
Sam
Nachricht 25 von 50
JDMather
You are missing obvious dimensions?
Nachricht 26 von 50
Nicht anwendbar
Thats ok ? or .. i missed something ..
rgs,
Sam
Nachricht 27 von 50
JDMather
Create a vertical construction centerline.
Sketch a circle as shown.
You will have to right click to enter the dimension as a Radius of 616.First Arc.png
Nachricht 28 von 50
Nicht anwendbar
thats ok ? 😛
Nachricht 29 von 50
JDMather
What did you do?
Notice that the sketch changed color indicating that it is no longer constrained?
Start over.
(and the instruction was to dimension as a radius - not a diameter)
Nachricht 30 von 50
Nicht anwendbar
ok ... i f**** something before ...
i think thats ok ?
Nachricht 31 von 50
JDMather
Nope, all wrong - and obvious.
Attach your *.ipt file here.
Nachricht 32 von 50
Nicht anwendbar
rgs,
Sam
Nachricht 33 von 50
JDMather
It might be best if I create a video.
Supper time right now - back in about an hour.
Nachricht 34 von 50
Nicht anwendbar
No problem ... thnx a lot for helping me out ...
Im going in bed .. here is 00:00 oclock, have job at 6 AM 🙂  ... so i will be online tomorrow all day ...
thank you one more time ...
And one question ?
Developing a Hardware .... etc ... is your book ? 🙂
Nice one btw if it is yours  ...
rgs,
Sam
Nachricht 35 von 50
JDMather
Do not go beyond the steps in this video (turn on your sound).
There are some critically important considerations that I must get information from you before proceeding to next step.
Nachricht 36 von 50
Nicht anwendbar
I think its ok ... 3 dimensions needed... rgs, Sam http://imageshack.com/a/img922/9977/pMlTw9.jpg
Nachricht 37 von 50
Nicht anwendbar
And thnx for a very good video ...
Nachricht 38 von 50
Nicht anwendbar
And btw this is the form from acad ... have to be like this one ... but i have to cut on the bottom for plates ... ( i will upload *.dwg somewhere because something wrong with attach files here ... )
Nachricht 39 von 50
JDMather
I don't go to third party image sites.
Attach your *.ipt file here and end all doubt.
Nachricht 40 von 50
Nicht anwendbar
sorry didnt know that...
rgs,
Sam
