Transition Constraint woes
RDG3PO
RDG3PO
I have what I think should be a simple motion, but isn't behaving properly. I'd like to drive or animate this later, but I suspect it won't go well with the behavior of the constraints as is.
The red triangle part should move from vertical when at the bottom, to horizontal when at the top. but the transitional constraints keep popping out of their tracks and running along the outside surfaces of the rectangle.
INVENTOR 2014 STANDARD
IOSX and PARALLELS
Mark.Lancaster
@RDG3PO
Your forum signature indicates you're using Inventor 2014 standard but the assembly was created in Inventor 2019.4..
Anyhow it was last saved with Inventor 2020.   Have you applied 2020.2 and tried again?  Just wondering if there was an issue with the original 2020 release.
Mark Lancaster
RDG3PO
yep, I haven't updated my signature in a while. Thanks for pointing that out. I'm running 2020 now, but I'll make sure the latest update is applied and try again.
IOSX and PARALLELS
JDMather
Expand the Relationships folder.
Right click on the Drive this constraint and select Drive.
andrewdroth
You might have better luck if you make distinct surface bodies for the transition constraints.
https://knowledge.autodesk.com/community/screencast/340f17bd-8370-4d1f-9e19-89e5f589e42a
Andrew Roth
rothmech.com
YouTube IconLinkedIn Icon
IV2025 Pro
Apple IIe Workstation
65C02 1.023 MHz, 64 KB RAM
Apple DOS 3.3
johnsonshiue
Hi! Yes, I agree with Andrew. You want to create a zero offset surface on the faces of the stationary part. Then edit the transitional constraint and select the surface body as the stationary face. This helps control the scope of transition. Otherwise, the constraint solver and move the part (pop) else where on the stationary part, since all faces on the part are fair game.
Many thanks!
Software Test Engineer
