Thicken feature breaking up on helical curve
viniciusfortes
viniciusfortes
Hi all,
I've been having this problem with a Helical curve template I've made and I can't seem to find a solution.
Two helical curves inside a 3D Sketch control the behaviour of the curve, a Loft Surface feature between them create the surface and then a Thicken feature with central (symmetric) direction behaviour thickens the surface into a solid.
Works fine and for a while I've had no problem at all.
And all of a sudden I came across a failed surface feature when I specify a certain length:
So far, I couldn't find an explanation and a way to fix it.
Just to make it even more disturbing, at other lenghts the error appears when zooming out and disappears when zooming in.
20231023_111131.mp4
Video Player is loading.
Current Time 0:00
Duration 0:49
Loaded: 19.94%
Stream Type LIVE
Remaining Time 0:49
1x
    • Chapters
    • descriptions off, selected
    • captions off, selected
    • en (Main), selected
    (view in My Videos)
    I appreciate enormously if someone could help me on this.
    The file is attached below.
    Using Inventor 2023 Build 359, release 2023.3.1 and all parts in mm.
    Vinicius.
    Replies (7)
    kacper.suchomski
    Looks like an error. I checked with a different method and got the same bug. @johnsonshiue
    Kacper Suchomski
    YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
    johnsonshiue
    Hi! The flat pattern will not work for this case. I tried using Guide Rail Sweep but the result was not better. The odd shape is bad faceting. It can be mitigated by splitting the faces using YZ or XZ plane. Unwrap can be used to flatten the faces.
    Many thanks!
    Software Test Engineer
    viniciusfortes
    Hi @johnsonshiue,
    Thanks for giving it a look.
    I'm not interested in flattening it, I just want to use it without this odd geometry.
    This is a parametric template that adjusts it's length by a giver numeric parameter.
    How exactly can I fix it by splitting the faces?
    By splitting it I wouldn't I be misrepresenting the real geometry?
    johnsonshiue
    Hi! The split is only on the faces, not separating the body. It is like adding additional edges.  The bad faceting will go away.
    Many thanks!
    viniciusfortes
    Hi @johnsonshiue!
    Thanks for the tip, but I couldn't manage to get the bad faceting to go away.
    Maybe I did something wrong. By any chance could you send the file you managed to do it?
    Many thanks
    20231102_185833.mp4
    Current Time 0:00
    Duration 0:20
    Loaded: 47.03%
    Stream Type LIVE
    Remaining Time 0:20
    1x
      • Chapters
      (view in My Videos)
      johnsonshiue
      Hi! I use origin planes to split the faces. It seems to work for me. Please take a look at the attached part.
      Many thanks!
      I've made a modification to the spiral. The extended ends did the trick, which you can see in de mp4. Hope this helps you. Marco
      Thicken feature breaking up repair suggestionThicken feature breaking up repair suggestion
      Type a product name
      ______
      icon-svg-close-thick
      Cookie preferences
      THIRD PARTY SERVICES
      icon-svg-hide-thick
      icon-svg-show-thick
      Qualtrics
      Akamai mPulse
      Digital River
      Dynatrace
      Khoros
      Launch Darkly
      New Relic
      Salesforce Live Agent
      Wistia
      Tealium
      Upsellit
      CJ Affiliates
      Commission Factory
      Typepad Stats
      Geo Targetly
      SpeedCurve
      Qualified
      icon-svg-hide-thick
      icon-svg-show-thick
      Google Optimize
      ClickTale
      OneSignal
      Optimizely
      Amplitude
      Snowplow
      UserVoice
      Clearbit
      YouTube
      icon-svg-hide-thick
      icon-svg-show-thick
      Adobe Analytics
      AdWords
      Marketo
      Doubleclick
      HubSpot
      Twitter
      Facebook
      LinkedIn
      Yahoo! Japan
      Naver
      Quantcast
      Call Tracking
      Wunderkind
      ADC Media
      AgrantSEM
      Bidtellect
      Bing
      G2Crowd
      NMPI Display
      VK
      Adobe Target
      Trendkite
      Hotjar
      6 Sense
      Terminus
      StackAdapt
      The Trade Desk
      RollWorks
      Your experience. Your choice.
