- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
I've been having this problem with a Helical curve template I've made and I can't seem to find a solution.
Two helical curves inside a 3D Sketch control the behaviour of the curve, a Loft Surface feature between them create the surface and then a Thicken feature with central (symmetric) direction behaviour thickens the surface into a solid.
Works fine and for a while I've had no problem at all.
And all of a sudden I came across a failed surface feature when I specify a certain length:
So far, I couldn't find an explanation and a way to fix it.
Just to make it even more disturbing, at other lenghts the error appears when zooming out and disappears when zooming in.
I appreciate enormously if someone could help me on this.
The file is attached below.
Using Inventor 2023 Build 359, release 2023.3.1 and all parts in mm.
Vinicius.
