I have been trying to find a way to make the text in my title block thicker when printing. I used the ticker vertion of the font style and bolded it, but it is still not enough. Is there any reliable/easy way to make the text thicker. Thank you for your help.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
This is what I currently have
This is more so what I want(edited in paint.net).
I am using RomanS_IV25(thicker than RomanS and same as RomanS_IV50) and all text is bolded(althought it doesn't seem to have an effect)
And you are correct, this isnt a printing problem persay, but I don't know if it could be solved with the print options possibly.
Ok, i've checked the font and it doesn't seem there is a bolder version.
You'll probably have to start looking for a different (similar) font.
I also tried changing the stretch value, but that also didn't seem to have any real effect on the thickness...
(as a suggestion, i've read a post saying "open sans condensed" is rather similar)
Niels van der Veer
The Netherlands
What you "currently" have looks much better IMO..
And I'm even from the US where getting "fatter" is the norm.
There is only so much you can do.. If a font isn't suitable there are thousands more to pick from.. Or just learn to create/modify your own TTF.. Selling "Bloated RomanS" could be your retirement plan
@Anonymous wrote:
, but we also don't want to change what we had in AutoCAD.
boom.. I knew that was the real issue..
Do you still light a fire by rubbing 2 sticks together?
You have defined a problem with the current font yet the solution is SO simple.
Just change the font. Go Arial or whatever and don't look back.
