Inventor Forum
Text problem
8 REPLIES 8
Message 1 of 9
422 Views, 8 Replies
Text problem
I am running Inventor version 11 and have a problem with text not showing.
For instance, if I want to add "Enlarged" to a section view text label, the text box appears and I type in "Enlarged" but the whole title goes away when I close out the text box.
Also, when I put in a datum identifier such as the letter A, it will show in the text box but will not appear after.
It seems I remember a Windows update being the source of the problem but I'm not sure about it.
Thanks in advance!
8 REPLIES 8
Message 2 of 9
JDMather
Have you installed all Hotfixes and Service Packs?
Message 3 of 9
Important Announcements
Hotfix to fix Text problem in IDW's has been released
http://usa.autodesk.com/getdoc/id=DL9229921
Many people are reporting problems adding text to IDW's after installing
Microsoft Windows 2000 Security Hotfix KB918118. Until this is resolved,
you should uninstall the Hotfix, and turn off automatic updates for
Microsoft
updates.
Dell 670 dual Xeon - 3.2
3gb memory, SCSI320-15k
XP-Pro, sp2
Quadro FX3400: Driver: 91.36 OpenGL
IV2008-pro sp2,
SpacePilot Rel V: 3.5.4 Dvr V: 6.4.4 Firmware 3.12
wrote in message news:5814163@discussion.autodesk.com...
not sure about it.
Thanks in advance!
Message 4 of 9
We started having similar text problems this morning on two of our three Inventor seats. I followed the link Blair posted and found the Hotfix for IV10. When I try to run it I get an error message saying;
"This Hotfix could not be installed because it is not designed for the version of Autodesk Inventor 10 that is installed on your computer."
If anyone can offer any suggestions it would be appreciated.
Thanks in advance,
Richard in Houston
Message 5 of 9
JDMather
Install Service Packs and Hotfixes in the order released.
Message 6 of 9
Ok, thanks JD
Message 7 of 9
You must have Inventor 10 Service Pack 3a installed before installing the
hotfix.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
260-399-6615
Instructor/Author/Sr. App Engr.
AIP 11SP3, AIP 2008 SP2, PcCillin AV
HP zv5000 AMD64 ( modified)
Geforce Go 440, Driver: .8185, 2GB RAM
XP Pro SP2, Windows XP Silver Theme
http://teknigroup.com
Message 8 of 9
dan_inv09
I'm curious, how is it that people are still just discovering this?
It's been almost a year since KB918118 started affecting Inventor, and it seems like about every month one or two people discover it for the first time.
Do they only use Inventor once in a while?
Are they using other software the rest of the time?
Is their design process that long before they have to make a drawing?
Like I said, I'm just curious. You should see some of the responses to people who asked about this a month or two after it first hit. I'm glad to see everyone's calmed down.
Message 9 of 9
Hey Dan, I was very puzzled by this as well. I use Inventor everyday, and create IDW's almost everyday. Somehow this problem didn't appear until yesterday. I first encountered it while trying to place text into a sketch in an IPT. Later it showed up when trying to edit a revision chart in an IDW.
I suspect there must be something involved besides just a MS Hotfix that's been there for over a year. However, my problem is solved, so I'm back to "if it works, don't fix it" mode.
Now you've got me curious about the earlier "responses". 🙂
