Table Wrap Text
This widget could not be displayed.
Table Wrap Text
How can you get the header text in a table to wrap to the next line? This
should be very basic.
Joe
Replies (9)
Rado_Paljus(Autodesk)
Please see this:
http://discussion.autodesk.com/thread.jspa?messageID=5735182
Unfortunately there is no change for this in 2009.
Rado
Has anyone found out how to do this yet?
I still can't work out how to do it with Inventor 2013.
(I'm using a "General Table" - if that makes any difference)
I guess they are interested in solving this issue.
I also face the same problem.
llorden4
2018...  Still waiting for this ability!
Autodesk Inventor Certified Professional
johnsonshiue
Hi! Let me get a bit clarification here. Do you want to have the title split in two lines? I thought it was doable already. Could you share an example of what you want?
Many thanks!
Software Test Engineer
mcgyvr
@llorden4
Its already possible to have the table header/column headers wrap..
It will wrap when the width of the column its bound to forces it to warap.
Now I suspect what you actually want is to choose where it wraps or to force a multiple line title/header..
That is not currently possible.
llorden4
Would be fantastic if you do, looking for an Excel type word wrap for column headers.
mcgyvr
@llorden4 instead of a movie please attach that idw/dwf file you are using..
It works just fine for me in 2018 but it would really help to have your actual drawing to investigate....
llorden4
Many thanks!
Did those video's help?  Should the column headers wrapped or were you thinking of the Table header (first/top box)?
The need for me pushing this feature is I have a very wide table and instead of being able to reduce the column width I have to instead reduce the font size in order to get the table to fit the sheet.
