Sweep Help
Sweep Help
Talayoe
Message 1 of 8
Sweep Help
Talayoe
Hi All,
Looking for a little bit help with this. Never had to try this before.
I have a pipe segment I need to get rolled locally. I need to start with a large rad at the front and smaller rad at the back (55" back from the front). I thot a sweep would work but it doesnt generate the small rad but rather just extends the large one to the back.
I have attached the file, 2022 format, so someone can see what I did and offer some insight if it makes sense.
Thanks a bunch!
-Randy
Inventor 2017 PDS
Replies (7)
Message 2 of 8
gmwi
Can you load a *step version of it. I'm on '21 and it doesn't open newer versions.
Message 3 of 8
Talayoe
Thanks for the reply. I wish I could, but its only geometry at this point. I think I may have over thought this and a revolve and cut might just be all I need to make this work. If I cant get this to work, I will post the revolve so you can see what I am after at least.
Tks!
-Randy
Inventor 2017 PDS
Message 4 of 8
gmwi
Do a screen shot. It sounds like you need to loft but I'm ASSuming a lot here.
Message 5 of 8
JDMather
You can open 2022 files in 2021 if you install Update 3.
But there isn't any solid geometry in the file.
Message 6 of 8
johnsonshiue
Hi! There are multiple ways to do this (see attached part). The quickest way is to use Loft Surface -> Thicken without recreating a lot of geometry. You can also use Guide Rail Sweep or Ruled Surface -> Thicken. The key is to ensure the thickness be consistent.
Software Test Engineer
Message 7 of 8
gmwi
Well, I'm waiting to see what the tech support is doing. I figured that it might but right now I'm not allowed to get it.
Message 8 of 8
Talayoe
This seems to be a fairly easy way to do it. 🙂
Thanks, and I appreciate all the other inputs as well!
-Randy
Inventor 2017 PDS
