iLogic Rule Error
iLogic Rule Error
ethan_howardMMXXV
Message 1 of 16
iLogic Rule Error
ethan_howardMMXXV
Hello everyone,
I've been using this Rule for about a month now and haven't run into any problems until now. Is there a reason that this same rule works in one part but not another?
 Sorry I can't share this file.
Autodesk Inventor Professional 2020
64-Bit Edition
Build: 373, Release: 2020.3.4 - Date: Fri 10/30/2020
Replies (15)
Message 2 of 16
andrewiv
Without seeing the rule it's impossible to tell what the problem might be.
Andrew In’t Veld
Designer / CAD Administrator
Message 3 of 16
ethan_howardMMXXV
@andrewiv See the attachments. Or I'll copy it here:
Error in rule: Wetted_Surfaces, in document: 17041FF3.ipt
Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))"
and
"System.Runtime.InteropServices.COMException (0x80004005): Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.Face.get_Appearance()
at ThisRule.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)"
Message 4 of 16
ethan_howardMMXXV
Also, here is the Rule:
'code to get the area of each face based on its color
Dim oPartDoc As PartDocument
oPartDoc = ThisApplication.ActiveDocument
Dim oFaces As Faces
oFaces = oPartDoc.ComponentDefinition.SurfaceBodies(1).Faces
Dim Colors As Object
Colors = CreateObject("Scripting.Dictionary")
Dim oFace As Face
For Each oFace In oFaces
    Colors(oFace.Appearance.DisplayName) = Colors(oFace.Appearance.DisplayName) + oFace.Evaluator.Area
Next
For Each Item In Colors
  MessageBox.Show("Color: " & Item & vbLf & "Area: " &Colors(Item) & "cm^2", "Surface Area by Color")
Next
Message 5 of 16
mcgyvr
Try this.. Tell us the last "Part X" message you see before getting the errror..
Likely makes it to part 3 but lets see..
Probably something bad about one of the faces.. Hard to tell without seeing the file...
You can also throw this at the beginning and see how it does and if there is a face it seems to miss reporting on or whatever.
On Error Resume Next
MessageBox.Show("Part 1", "Made it")
Dim oFaces As Faces
MessageBox.Show("Part 2", "Made it")
MessageBox.Show("Part 3", "Made it")
Dim oFace As Face
Next
MessageBox.Show("Part 4", "Made it")
Next
Message 6 of 16
ethan_howardMMXXV
Part 3 was the last file before the Error.
Error in rule: mcfyvr, in document: 17041FF3.ipt
and
at ThisRule.Main()
Message 7 of 16
ethan_howardMMXXV
Message 8 of 16
ethan_howardMMXXV
This is the file structure. Are you leaning towards one of the ipt files being the culprit?
Message 9 of 16
ethan_howardMMXXV
There are no "Recovery" errors in the file:
Message 10 of 16
johnsonshiue
Hi Ethan,
The "oFaces" expression needs to be rewritten as the following.
oFaces = oPartDoc.ComponentDefinition.WorkSurfaces.Item(1).SurfaceBodies.Item(1).Faces
Many thanks!
Software Test Engineer
Message 11 of 16
ethan_howardMMXXV
On "Error Resume Next" worked!!! I tried that for both "Rules". It ran "Part 4" and ran the correct "Surface Area by Color". Very cool! I'm adding that line to my Rule. Thanks man!
Message 12 of 16
ethan_howardMMXXV
@johnsonshiue that did not work. I ran into the same error so I added "On Error Resume Next". It must have run because I didn't receive an error but it didn't display a menu (report).
Message 13 of 16
ethan_howardMMXXV
@johnsonshiue
Here is your rule with the added text in front:
Dim oFaces As Faces
oFaces = oPartDoc.ComponentDefinition.WorkSurfaces.Item(1).SurfaceBodies(1).Faces
Dim oFace As Face
Next
  MessageBox.Show("Color: " & Item & vbLf & "Area: " &Colors(Item) & "cm^2""Surface Area by Color")
Next
Message 14 of 16
ethan_howardMMXXV
@johnsonshiue I am willing to try other fixes.
Message 15 of 16
mcgyvr
@ethan_howardMMXXV  WARNING.... All thats doing is hiding the error and letting the rule continue to run.
Its highly likely that one or more faces are erroring out and being excluded from your final results.
You should be able to now see which color isn't being shown in your result messages and then see which faces have that color assigned as potentially give a clue into whats going on with those.
Message 16 of 16
ethan_howardMMXXV
@mcgyvr there are only two colors and both are showing results. Is there a rule to diagnose the surface causing the error? Or can you only diagnose at the part level? We've narrowed it down to "Part 4" as being the problem. I would think that that is the last part in the history tree.
