For some reason, I am unable to create a structured Parts List in the drawings. (Watch attached video)
Can anyone help in this question?
Solved by johnsonshiue. Go to Solution.
Hi! I believe you may have a PartOnly PartsList from the same assembly in the drawing, right? The behavior you are seeing is a preventative measure avoiding item# collision. When you have a PartOnly PartsList of an assembly, you can only create PartOnly PartList of the same assembly within the same drawing, likewise for Structured.
There is a backdoor access however, Start a new drawing and then create a Structure PartsList for the same assembly -> copy the sheet and paste it to the old drawing.
Many thanks!
@paberzsvaldis You have not enabled it in the BOM of the assembly file!
@johnsonshiue Will this function in future releases too!? I would be very careful with these kind of tricks!
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Of the assembly file I have enabled 'structured' and 'parts only' BOM View. (Watch attached video)
Did not fully understand how it works, but, creating a new drawing file, allowed me to create structured part list for for the main assembly, and PartOnly for other sub assembly.
Thanks for the help.
