Inventor Forum
Strange discrepancy between model and drawing dimensions.
10 REPLIES 10
Message 1 of 11
erikjan.koeze
385 Views, 10 Replies
While trying to figure out why I can not get precise dimensions on a specific part, I chose to remodel it to make sure nothing I did was wrong. Results are the same...
How do I get the dimension to accurately display as 20mm without rounding it to a lesser precision?
See attachments for screenshots of model and drawing of the same section.
10 REPLIES 10
Message 2 of 11
CCarreiras
in reply to: erikjan.koeze
There's no attachements... anyway, i believe this should help you:
https://knowledge.autodesk.com/search-result/caas/simplecontent/content/inventor-places-incorrect-di...
CCarreiras
Message 3 of 11
erikjan.koeze
in reply to: CCarreiras
Thanks. Screenshots are attached now.
Message 4 of 11
CCarreiras
Well.... we can do nothing with images, we have to check the model....
CCarreiras
Message 5 of 11
erikjan.koeze
I have attached the files (idw and ipt).
Running Inventor 2022.3 build 350
Message 6 of 11
CCarreiras
I guess the template has some issue, try another template.
For me, it works well...
CCarreiras
Message 7 of 11
erikjan.koeze
Can you try with a higher precision? Dimension is 20.00015 in my drawing.
Message 8 of 11
CCarreiras
If I set bigger precision, I will have the same result as you.
I guess this is due to the curved surface of the tube.
...but, the question is... why do you need to increase precision to that level?!
CCarreiras
Message 9 of 11
erikjan.koeze
I don't need the precision. I'm curious what would cause this. Is it my modelling or is it something strange.
If I place the same dimension in another view, again on the centerline, the dimension IS correct, which makes it even more peculiar...
Message 10 of 11
CCarreiras
The dimensions are placed based on the geometry projection.
I think this issue occurs due to the projected hole geometry in the curved tube surface, which adds some imprecision... ...but is a "residual imprecision", regarding product documentation and the precision required for that, is more than enough, don't worry about that.
CCarreiras
Message 11 of 11
Hi Erikjan,
This is an Inventor limitation. The reason why the diameter dimensions are slightly off is because the edges associated with the dimensions are intersection curves (between two perpendicular cylinders). The geometry is spline. As a result, the project of the spline edge is also a spline. Inventor utilizes approximation to get the diameter value within a predefined tolerance.
If the precision is set to 0.001, this behavior will not be seen. This is why Carlos thinks a different template file matters (precision settings).
We have been investigating a solution. But, there is no good solution yet. It is because the circular approximation is leveraged in many places. To get a true reading, the tolerance needs to be very high or there needs to be a special rule only applicable to the intersection between perpendicular cylinders.
Many thanks!
Software Test Engineer
