Strange discrepancy between model and drawing dimensions.
erikjan.koeze
erikjan.koeze
While trying to figure out why I can not get precise dimensions on a specific part, I chose to remodel it to make sure nothing I did was wrong. Results are the same...
How do I get the dimension to accurately display as 20mm without rounding it to a lesser precision?
See attachments for screenshots of model and drawing of the same section.
Replies (10)
CCarreiras
There's no attachements... anyway, i believe this should help you:
https://knowledge.autodesk.com/search-result/caas/simplecontent/content/inventor-places-incorrect-di...
CCarreiras
erikjan.koeze
Thanks. Screenshots are attached now.
CCarreiras
Well.... we can do nothing with images, we have to check the model....
CCarreiras
erikjan.koeze
I have attached the files (idw and ipt).
Running Inventor 2022.3 build 350
CCarreiras
I guess the template has some issue, try another template.
For me, it works well...
CCarreiras
erikjan.koeze
Can you try with a higher precision? Dimension is 20.00015 in my drawing.
CCarreiras
If I set bigger precision, I will have the same result as you.
I guess this is due to the curved surface of the tube.
...but, the question is... why do you need to increase precision to that level?!
CCarreiras
erikjan.koeze
I don't need the precision. I'm curious what would cause this. Is it my modelling or is it something strange.
If I place the same dimension in another view, again on the centerline, the dimension IS correct, which makes it even more peculiar...
CCarreiras
The dimensions are placed based on the geometry projection.
I think this issue occurs due to the projected hole geometry in the curved tube surface, which adds some imprecision... ...but is a "residual imprecision", regarding product documentation and the precision required for that, is more than enough, don't worry about that.
CCarreiras
johnsonshiue
Hi Erikjan,
This is an Inventor limitation. The reason why the diameter dimensions are slightly off is because the edges associated with the dimensions are intersection curves (between two perpendicular cylinders). The geometry is spline. As a result, the project of the spline edge is also a spline. Inventor utilizes approximation to get the diameter value within a predefined tolerance.
If the precision is set to 0.001, this behavior will not be seen. This is why Carlos thinks a different template file matters (precision settings).
We have been investigating a solution. But, there is no good solution yet. It is because the circular approximation is leveraged in many places. To get a true reading, the tolerance needs to be very high or there needs to be a special rule only applicable to the intersection between perpendicular cylinders.
Many thanks!
Software Test Engineer
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
