Inventor Forum
STL to IPT
24 REPLIES 24
Message 1 of 25
vmontefusco
92440 Views, 24 Replies
STL to IPT
Greetings
I'm working in Inventor Pro 2018 and it is updated
I was sent me an STL part file and it opens OK in Inventor and I can move it around. Can I convert it to an IPT so I can tweak it?
Vince
EFX Film & TV
24 REPLIES 24
Message 21 of 25
vmontefusco
in reply to: JDMather
This is complicated. Aside from how you wanted me to Add it, what is the process for Solid Edit Tools?
Vince
Message 22 of 25
Perfect! 🙂
Message 23 of 25
Hikakiller
in reply to: BeKirra
@BeKirra That's not converting anything, that's just saving it as an IPT.
@Hikakiller post has been moderated due to ground rule violation. Please stick to the ground rules. Thanks.
Message 24 of 25
BeKirra
in reply to: Hikakiller
OP was asking to convert a STL to IPT.
Now you jumped in and say "That's not converting anything".
If you are keen to learn then please ask people here to guide you how to ask a question.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
Message 25 of 25
johnsonshiue
Hi @Hikakiller,
Is it about converting to a solid in an ipt or exporting a solid to an stl? Do you mind sharing an example that you have trouble with?
Many thanks!
Software Test Engineer
