Inventor Forum
STL to IPT
24 REPLIES 24
Message 1 of 25
vmontefusco
91362 Views, 24 Replies
STL to IPT
Greetings
I'm working in Inventor Pro 2018 and it is updated
I was sent me an STL part file and it opens OK in Inventor and I can move it around. Can I convert it to an IPT so I can tweak it?
Vince
EFX Film & TV
24 REPLIES 24
Message 2 of 25
BeKirra
in reply to: vmontefusco
Under the big "I", "Save As" is the command you should use.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
Message 3 of 25
vmontefusco
in reply to: BeKirra
Greetings
I did what you said and it converted to IPT but I can't edit it. See attached. I will ask Autodesk to jump in on this one if you can't figure out how I can edit the part like a normal IPT part.
Vince
Message 4 of 25
johnsonshiue
Hi! If you are a subscriber, you can download Mesh Enabler from App store. It will convert the mesh to a composite node (each mesh face as a surface body). Then you can stitch it into a solid if the faces are water-tight. Please note that, the mesh edges will remain there. The topology will be necessarily complicated.
https://apps.autodesk.com/INVNTOR/en/Detail/Index?id=6950391119076900441&appLang=en&os=Win32_64
Another option is to use Fit Mesh Face command to fit a Brep surface by selecting the mesh. This particular part looks relatively simple. You might be able to fit quite a few faces. Lastly, you can always recreate the body from scratch. You can create a sketch on a planar mesh face and project points for reference purpose. You can recreate the part relatively quickly.
Many thanks!
Software Test Engineer
Message 5 of 25
vmontefusco
in reply to: johnsonshiue
Greetings Johnson
I downloaded like you suggested and followed the screen shot of R clicking on the mesh in the browser and I do not see the Convert to Base Feature in the list. I've attached the part I'd like to convert. Also, the 2017 reviews don't seem impressive. Hopefully, issues were fixed for the 2018 version I have.
Thank you!!!
Vince
Message 6 of 25
vmontefusco
Sorry forgot to attach Part.
Vince
Message 7 of 25
JDMather
@vmontefusco wrote:
... Also, the 2017 reviews don't seem impressive. Hopefully, issues were fixed for the 2018 version I have.
Thank you!!!
Vince
What is the source of your information - please include url reference?
Exactly what "issues" are you referring to?
Message 8 of 25
vmontefusco
in reply to: JDMather
Message 9 of 25
@vmontefusco wrote:
Greetings Johnson
Thank you!!!
Vince
What issues are your referring to?
Mark Lancaster
Message 10 of 25
JDMather
Scroll down to the reviews
Thank you
Vince
Ah, so you are referring to the Mesh Enabler, not Inventor.
I have never had trouble with the Mesh Enabler, but I have found that a significant set of users have no clue of the nature of stl files.
Stl files are simplified triangular faceted planar surfaces - generally of little use in an MCAD environment other than for 3D Printing.
The image/file you attached would be more useful models as proper parametric b-rep geometry.
Do you have the original file - or is the stl file someone else's work?
Message 11 of 25
vmontefusco
I have Inventor Pro 2018 subscription and was told I could download Mesh Enabler to convert STL files sent to me to IPT parts that I could tweak normally. The STL files sent to me are being used for 3D Printing. I now assume what I want to do can't be done??
Vince
Message 12 of 25
vmontefusco
The STL file is from someone else. See attached.
Vince
Message 13 of 25
JDMather
@vmontefusco wrote:
....parts that I could tweak normally.
Vince
What is the source of this information?
Sure you can edit the parts once you have run the Mesh Enabler to convert the surfaces to solid body - but have you closely examined an stl geometry?
Message 14 of 25
JDMather
Vince
Is  there a reason that you have attached the same stl file here three times?
Message 15 of 25
vmontefusco
No, I thought you were asking for it. I see what I want to do is problematic, so I will just duplicate the STL's that are send to me. Some of the STL's are more complex, but I'll just have to adjust my schedule.
Thanks for all of your help!!
Vince
Message 16 of 25
JDMather
Cutting, for example - drilling holes) in a converted stl is not a big issue.
Adding geometry might not be a big issue.
But changing the size of existing geometry can be a big issue as your part consists of over 157 thousand individual faces.
If you were expecting a feature tree - you are only going to get a "dumb solid".
For freeform editing of stl mesh you can use another product - Mesh Mixer - but for the types of geometry that you posted it is far easier to remodel with primitives like cylinders and boxes.  Simple Revolves and Extrudes.
Message 17 of 25
vmontefusco
Sorry for basic responses, you are way above my pay scale!!
I opened the part that I've attached (3x's) and tried to create hole using sketch on an an origin plane and it says it has no volume. I understand the mess volume thing, but how would I add features to it. I respect your time and if this is a major detail explanation, then I will live with the STL's and recreate them so I will have full control over there designs.
Thanks again
Vince
Message 18 of 25
JDMather
@vmontefusco wrote:
.. it says it has no volume.
From your earlier responses it sounds like you never got the Mesh Enabler loaded properly.
Go to your Tools>Addins and make sure that it is loaded.
Then expand and right click on the MeshFeature node and select Convert to Base Feature (and select Solid Body).
Message 19 of 25
vmontefusco
I did what you suggested and it is now loaded and I see the Convert to Base Feature. It took a while to complete using the part I attached. Then I double clicked in the browser and a new set of tools appeared, not the usual look when you edit an extruded part. I will play around with it.
Thank you
Vince
Message 20 of 25
JDMather
Thank you
Vince
I don't think you want to do that if you want access to the usual editing tools.
Sounds like you got into the reduced set Solid Edit tools.
Technology Administrators
