Greetings
I'm working in Inventor Pro 2018 and it is updated
I was sent me an STL part file and it opens OK in Inventor and I can move it around. Can I convert it to an IPT so I can tweak it?
Vince
EFX Film & TV
Solved by JDMather. Go to Solution.
This is complicated. Aside from how you wanted me to Add it, what is the process for Solid Edit Tools?
Vince
@BeKirra That's not converting anything, that's just saving it as an IPT.
@Hikakiller post has been moderated due to ground rule violation. Please stick to the ground rules. Thanks.
OP was asking to convert a STL to IPT.
Now you jumped in and say "That's not converting anything".
If you are keen to learn then please ask people here to guide you how to ask a question.
HTH
Hi @Hikakiller,
Is it about converting to a solid in an ipt or exporting a solid to an stl? Do you mind sharing an example that you have trouble with?
Many thanks!
