Inventor Forum
STEP file import and save issue
30 REPLIES 30
Message 1 of 31
1849 Views, 30 Replies
I am having an issue with a vendor STEP file. After the file is imported into Inventor the program locks up when trying to save.
Has anyone experienced a similar issue? Any suggestions would be greatly appreciated.
I have attached the STEP file from the vendors download center.
30 REPLIES 30
Message 2 of 31
mdavis22569
Mike Davis
Message 3 of 31
in reply to: mdavis22569
Mike,
The issue is not in opening up the file. The issue is when I save the model the program becomes unresponsive.
Thank you for the reply.
Message 4 of 31
mdavis22569
I saved it twice ... once as an assembly with A LOT of assemblies in it ...
then
I did it again as an IPT.
Are you saving it locally ..or to a network location?    What version of inventor? Also do you have all of the patches...
Mike Davis
Message 5 of 31
The other thing I would add to mdavis22569 posting...   Do you ever see the Save dialog?  Just wondering if the dialog is off the screen...
Mark Lancaster
Message 6 of 31
Mike,
I am saving it to a local drive. I am using Inventor 2016 included in the Product Design Suite. I am not sure of the patches. Is there a place this information is readily available?
Message 7 of 31
in reply to: Mark.Lancaster
Mark,
I am seeing the dialog. The issue begins after I click save.
Thanks for the reply.
Message 8 of 31
mdavis22569
https://knowledge.autodesk.com/support/inventor-products/downloads
Can you try saving it to a different location?
Mike Davis
Message 9 of 31
mdavis22569
what about if you try another step file?
Mike Davis
Message 10 of 31
JDMather
In my first attempt it did not save (or not within a reasonable time).
I then saw that it had a bunch of sub-assemblies, most with only one part.
I then promoted all of the parts to the top level assembly and deleted all of the sub assemblies.
Then I ran Repair on all of the parts.
Message 11 of 31
Mike,
I tried changing the file location in the import dialog box to folder on my desktop.
This resulted in the same unresponsiveness.
I also created a project in a folder on my desktop and tried importing and saving while that project was activated.
This also resulted in the same unresponsiveness.
Regarding the service packs, is there a way to see what service packs are installed inside Inventor?
Message 12 of 31
Mark.Lancaster
Im wondering if your Inventor is not properly registered..  DO the following:
1.  Exit Inventor
2.  Click the WIndows start button and type CMD in the search field but do not hit an enter.
3.  When CMD.exe appears in the list, right mouse click on it and select Run as Administrator.
4.  In the command prompt, navigate to C:\Program Files\Autodesk\Inventor <version\Bin
5.  Type Inventor /install.
6.  Wait a few minutes and then restart Inventor and test your workflow again.
Mark Lancaster
Message 13 of 31
mdavis22569
go to your about Inventor in the right corner
or go to control panel ... programs, installed updates on the left side and scroll to inventor and see what ones are installed.
What if you get another step file of something else, do you have an issue then too?
Mike Davis
Message 14 of 31
Mark,
That very well could be the issue, as we just began using the Product Design Suite. I will have to direct this issue to IT, as I do not have administrator privileges.
Would this cause issues all the time, or intermittently? I only ask because I've imported many models prior to this particular model with out issues.
Message 15 of 31
in reply to: JDMather
JD,
This worked for me as well. However, the way I did it seemed tedious. Unless there is a way to select all parts at once to promote, this would be undesirable.
Message 16 of 31
Mike,
I have tried a different STEP file without issues.
My About is as follows:
Autodesk Inventor Professional 2016 64-Bit Edition
Build: 138, Release: 2016 RTM - Date Fri 02/27/2015
Usage Type: Commercial
License Expiration: No Expiration
License Behavior: Permanent
Message 17 of 31
mdavis22569
You need to do your updates
I believe you should be at Build 210 once you have them all installed.
edited:
yes 210
Mike Davis
Message 18 of 31
JDMather
@Anonymous wrote:
...it seemed tedious. ....
Well, rather than Component>Promote you can simply drag and drop from sub to main assembly.
But you do have to drag each part individually.
Message 19 of 31
Mike,
I will give that a shot. I appreciate your assistance.
Message 20 of 31
JD,
I will keep this method in mind for when I need to move components into the top-level. Any suggestions on moving a large number of parts more efficiently?
