I have been happily using joint constraints, but I have been experiencing a bug which I hope someone can help me with.
When I change geometry which breaks an existing joint contstriant I am having problem repairing the joint. If there is more than one broken constraint and I don't delete the other broken constriants I am not repairing, Inventor will not allow me to repair the joint. There is no button to accept the broken constriants and I must click ok or cancel. This is a little frustrating, but what happens next is worse. The parts and constraints in the browser no longer highlight when I select them and any further work will not be stored in memory, even if the work is saved. Eventually the software crashes and I lose any work performed after the last save before the error. My practice now is to save after this occurs and re-start my whole machine. This seems to be the only failsafe mode for managing how much work is lost.
Is Autodesk aware of / fixing this error?
Cheers.
Welcome to the forum.
I absolutely hate this error.... it's hard not to use every negative word I have in my vocabulary to describe my feeling about it :))
Hope it gets fixed soon.
in regards to loose of work and crashed I must admit that I am not getting that. Have you installed latest service packs and updates?
I tried joints (not "joint constraints", they are two seperate kinds of relationships) a few times and then returned to using constraints. I don't see benefits that outweigh the downsides, though I'm not using Dynamic Simulation-- that would probably tip the balance.
Sam B
Inventor Professional 2016 Update 2
Vault Basic 2016
Windows 7 Enterprise 64-bit, SP1
I actually like them especially since you need only one for every 3 constraints.
What I don't like is that you need to select faces and edges and that goes hard against my rule to pick origin features as much possible.
They are recommended with large assemblies if only they would work properly....
Anyone have any updates on this?
I cant get it to work on my computer.
Maybe Inv 2017 fixes it?
Does it need to be posted in the IdeaStation to be flagged as a bug for Autodesk to look at?
I really like the intention of this function, but still not usable, unfortunately.
Xun,
please also see this thread, where it is well described:
Thank you All for the help, yes, as what've replied in previous thread, the Accept button missing is a problem to me. it was tracked internally and the track ID = Bug59663, By the way, the unstable state is caused by accept option missing, so let fix the problem first and then see what's going on.
Thanks again for all of your great help, I will reply back for any progress if we have.
