Inventor Forum
Spline length
5 REPLIES 5
henrikubbe4438
6983 Views, 5 Replies
Spline length
henrikubbe4438
Hi all
Is there a way to measure the lenght of a 2D spline curve?
/Ub
Spline length
Hi all
/Ub
5 REPLIES 5
-niels-
in reply to: henrikubbe4438
-niels-
In sketch mode you can use the normal "measure distance" to get the length of a spline.
At least, when i drew a spline and started "measure distance" on hovering over the spline the box text changed to "length".
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Niels van der Veer
The Netherlands
henrikubbe4438
As always, something simple...:)
Thanx
/Ub
Thanx
/Ub
Many thanks man!
Many thanks man!
trobinson
trobinson
How can the length of a spline be used as a reference dimension or parameter?
johnsonshiue
in reply to: trobinson
johnsonshiue
Hi! There are multiple ways to do that. You may write a simple iLogic rule and capture the spline length value in a user parameter. Or you may create a 3D Sketch -> Include Geometry -> pick the 2D spline curve. Add a length dimension to the 3D spline. A driven dimension will be created.
Many thanks!
Software Test Engineer
Many thanks!
