Solved by -niels-. Go to Solution.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Niels van der Veer
The Netherlands
Many thanks man!
How can the length of a spline be used as a reference dimension or parameter?
Hi! There are multiple ways to do that. You may write a simple iLogic rule and capture the spline length value in a user parameter. Or you may create a 3D Sketch -> Include Geometry -> pick the 2D spline curve. Add a length dimension to the 3D spline. A driven dimension will be created.
Many thanks!
Many thanks!
