Specialized BOM
Specialized BOM
Message 1 of 9
Specialized BOM
I want to set up a BOM style to speed up submittal drawings for steel tanks. The new BOM would have Item (lettered), Size (from iproperties "AUTHORITY"), and Description (Manually entered) So it would show up like this;
Is there a way to get the item default set to letters instead of numbers?
How can I keep identical parts from merging? With a regular BOM, B and C would merge and say QTY of 2.
Replies (8)
Message 2 of 9
rush02112
To get Alpha numbering in BOM do the following:
RMB on the Parts Only tab and enable it, then RMB again and go to View
Properties. Change numbering to Alpha.
Then hit Renumber on the BOM toolbar, and start with A (there seems to be an
issue here with how we default in the renumber dialog, just make sure to
change the 1 to A).
If your parts lists numbers are not already overwritten (typically a
migrated file) all parts lists associated with that assembly will update.
Note that if know that you ALWAYS want alpha IDs, change that setting in
your assembly template so you won't have to renumber.
to keep the rows of B & C from merging, the part # under the project tab in the iproperties have to be different, from my experience
Message 3 of 9
I don't want to change assembly settings because I still need to make a weld drawing with integer numbering
Its head scratcher.
Message 4 of 9
Save two different drawing templates.  One for Assemblies and one for Weldments.
Message 5 of 9
salariua
Did a test and I've managed to change it wit iLogic but you face a bigger problem.
How are you going to synchronize this on multiple sheets, drawings? to make them consistent?
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
Message 6 of 9
MechMachineMan
Make it as a custom iProperty in the component level. Get the PartsList to show this custom property (that will be the alpha numbering) that corresponds to the part, instead of the Item Number.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 7 of 9
salariua
I think @MechMachineMan is referring to this: Coordinated bom
the only worry is you will run out of letters Smiley LOL
Adrian S.
blog.ads-sol.com
Message 8 of 9
He could always switch language to Khmer, 72 letters?Smiley Wink
Message 9 of 9
Thought about another approach. I could use the Item # as the description but I still have a problem with combining occurrences of the same part.
The real end goal is to get inventor to generate sizes without just using leader text. About a month ago someone sent out a submital with the wrong fitting called out even though it was the correct size on the model, and on the BOM, and built by the weldshop, the customer wanted to back charge because it was different than approved.
