Spec PC for Inventor
hilmiN4XCX
Observer Observer
hilmiN4XCX
Observer
Observer
hello, may i ask, this spec can run Inventor Pro 2024 and heavy part ?
-. INTEL: Core i5-14400F | MSI Pro B760M-A (Wi-Fi 6E + BT 5.3)
-. Graphics Card: NVIDIA GeForce RTX 4060Ti 16GB GDDR6
-. Cooler: AIO Liquid Cooler - ID-Cooling FX240 ARGB (Black)
-. RAM: 32GB Dual Channel DDR5 RAM 5200MHz - 2 X 16GB
-. 500GB Kingston NV2 PCIe 4.0 NVMe SSD
-. Power Supply: FSP HV Pro 650W 85+ Bronze Non Modular
-. Operating System: Genuine Windows 11 Professional 64-Bit OEM Edition
Gabriel_Watson
If by "heavy part" you mean complex assemblies, then I would just bump the RAM to 64GB:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/System-requirement...
If you can spend more on a better processor, that would be another good return on investment too. It all depends on the size (and level of mess) of your design files. Bad design practices or meshes and badly-imported geometry will always impact performance the most.
James_Willo
I'm sorry I can't guarantee specific setups, but the recommended specs are here:
Also remember that if you want to use ray tracing, only specific graphics cards are supported.
https://help.autodesk.com/view/INVNTOR/2024/ENU/?guid=GUID-541FB861-54C5-4D90-851F-575EFC15EC0C
In general though, for big files, you want lots of ram. I would say the i5 is probably a bit under powered, but that is just personal opinion, I have no test results to back that up.
James W
Inventor UX Designer
