I have created a sheet metal enclosure for a third-party power supply. The enclosure needs to reference features on the power supply so I derived the power supply part into my enclosure part.
I have finished my enclosure design. I cannot create a flat pattern because my part is multi-bodied. I want to delete the 110 solid bodies of the power supply but I can't.
I have tried using Delete Face with Void ON. This removes the item from the display but keeps the solid body in the model tree. It only 'removes' one solid at a time. I would need to do this 110 times to delete the whole power supply but it would be pointless because I would still be left with all of the solid bodies.
I have tried to creating a new solid that surrounds the power supply and then use Combine to subtract the many solids of the power supply but I get the error "problems trimming and discarding faces".
What is a simple and reliable way of deleting solids?
Thanks.
