Hello All,
Inventor - 2023
I have a drawing template 'A' which has few sheet formats and most of these sheet formats have a sketch symbol included with them.
So in Template 'A' if I double click the sheet format, everything works fine, even the sketch symbol automatically comes at the desired location.
Now I have another Drawing Template 'B' which does not have the sheet format, so I copied the sheet format from 'A' to 'B' , but if I double click the same sheet format in 'B' , the sketch symbol is not visible.
Kindly tell me what to do about this? How to resolve this.
Solved by johnsonshiue. Go to Solution.
I can't say anything for sure without having access to the files, but if it's a sketched symbol referenced in the format, you'll probably need to copy the sketched symbol itself as well.
I copied the sketch symbol to the new template before copying the Sheet format and checked, still not working
Hi! It sounds like a bug to me. I will work with the project team to understand it better.
Many thanks!
Thank you for the info.
Because of IP issue's I cannot upload any file or recordings here for more clarity. Hope you understand.
Please do update me when you have some progress!
Hi! I have contacted the project team. Unfortunately, it is currently a limitation in Sheet Format workflow. Sketch symbols are not included when the format is replicated.
Many thanks!
