Inventor Forum
Sketch Symbol missing when sheet format is copied to drawing template
7 REPLIES 7
Message 1 of 8
Pranesh_Thugru
257 Views, 7 Replies
Hello All,
Inventor - 2023
I have a drawing template 'A' which has few sheet formats and most of these sheet formats have a sketch symbol included with them.
So in Template 'A' if I double click the sheet format, everything works fine, even the sketch symbol automatically comes at the desired location.
Now I have another Drawing Template 'B' which does not have the sheet format, so I copied the sheet format from 'A' to 'B' , but if I double click the same sheet format in 'B' , the sketch symbol is not visible.
Kindly tell me what to do about this? How to resolve this.
Labels (2)
7 REPLIES 7
Message 2 of 8
I can't say anything for sure without having access to the files, but if it's a sketched symbol referenced in the format, you'll probably need to copy the sketched symbol itself as well.
_______________________________________________________________________________________
Intel Core i9-14900KF
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Inventor 2024 Professional
Message 3 of 8
I copied the sketch symbol to the new template before copying the Sheet format and checked, still not working
Message 4 of 8
Hi! It sounds like a bug to me. I will work with the project team to understand it better.
Many thanks!
Software Test Engineer
Message 5 of 8
Thank you for the info.
Because of IP issue's I cannot upload any file or recordings here for more clarity. Hope you understand.
Please do update me when you have some progress!
Message 6 of 8
Hi Everyone, any suggestions / update on this topic?
Message 7 of 8
Hi! I have contacted the project team. Unfortunately, it is currently a limitation in Sheet Format workflow. Sketch symbols are not included when the format is replicated.
Many thanks!
Message 8 of 8
Thank you for your reply.! Hopefully this will be rectified in future release!
