Inventor Forum
Welcome to Autodeskโ€™s Inventor Forums. Share your knowledge, ask questions, and explore popular Inventor topics.
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
Sketch mode move base point changing
7 REPLIES 7
Message 1 of 8
modracek
805 Views, 7 Replies
modracek
Inventor 2020, I took a short video. Im taking a 2d drawing and making it 3d, moving some things around in the process. I cant trust the move command though. Is there a solution? Know that ive noticed it im concerned I have to toss hours and hours worth of work ๐Ÿ˜ž
7 REPLIES 7
Message 2 of 8
swalton
in reply to: modracek
swalton
Where are all the dimensions?
I would never trust a sketch that shows 732 dimensions needed to behave in any predictable fashion.
Are you trying to use the Inventor sketcher like AutoCAD?
Steve Walton
Inventor 2024
Vault Professional 2024
Steve Walton
Inventor 2024
Message 3 of 8
modracek
in reply to: swalton
modracek
Yea I imported a DXF from autocad and was going to move some things around. Not that simple, huh?
Message 4 of 8
swalton
swalton
It can be...
Without dimensions or constraints, it is possible to inadvertently change the sketch geometry with mouse drags.
Try making each shape a sketch block.  I see several repeated shapes, so you can delete the extra lines, and just repeat the various blocks.  If you want, you can dimension each shape inside its block.
Once you have the blocks, you can drag them around, or add dimensions to control their position.
See: http://help.autodesk.com/view/INVNTOR/2020/ENU/?guid=GUID-D4403D63-95CE-4392-A73E-DBB1B8C8C110
Steve Walton
Inventor 2024
It can be...
Steve Walton
Inventor 2024
Message 5 of 8
JDMather
JDMather
@modracek wrote:
...Not that simple, huh?
Actually - it is simple if you convert those to Sketch Blocks as suggested by @swalton .
Attach your file here if you can't figure it out.
Message 6 of 8
lena.talkhina
lena.talkhina
Hello @modracek  !
Great to see you here on Inventor Forum.
Did any comment helped you to find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
If not please don't hesitate to give an update here in your topic so all members know what ฬs the progression on your question is and what might be helpful to achieve what you ฬre looking for. ๐Ÿ™‚
ะะฐั…ะพะดะธั‚ะต ัะพะพะฑั‰ะตะฝะธั ะฟะพะปะตะทะฝั‹ะผะธ? ะŸะพัั‚ะฐะฒัŒั‚ะต "ะะ ะะ’ะ˜ะขะกะฏ" ัั‚ะธะผ ัะพะพะฑั‰ะตะฝะธัะผ! | Do you find the posts helpful? "LIKE" these posts!
ะะฐ ะฒะฐัˆ ะฒะพะฟั€ะพั ัƒัะฟะตัˆะฝะพ ะพั‚ะฒะตั‚ะธะปะธ? ะะฐะถะผะธั‚ะต ะบะฝะพะฟะบัƒ "ะฃะขะ’ะ•ะ ะ”ะ˜ะขะฌ ะ ะ•ะจะ•ะะ˜ะ•" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
ะ›ะตะฝะฐ ะขะฐะปั…ะธะฝะฐ/Lena Talkhina
ะœะตะฝะตะดะถะตั€ ะกะพะพะฑั‰ะตัั‚ะฒะฐ - ะ ัƒััะบะธะน/Community Manager - Russian
Hello @modracek  !
Message 7 of 8
A.Acheson
in reply to: lena.talkhina
A.Acheson
I see the same behaviour in creating symbols. If you copy a sketch in from AutoCAD and do not want to dimension  it fully  the move command at base point fails to stick at the corner you select. By the end of the move the sketch item has moved away from the cursor.
There is no block command in the symbol sketch .
If this solved a problem, please click (accept) as solution.โ€Œโ€Œโ€Œโ€Œ
Or if this helped you, please, click (like)โ€Œโ€Œ
Regards
Alan
Regards
Alan
Message 8 of 8
johnsonshiue
johnsonshiue
Hi Alan,
Indeed, it would be nice if Inventor drawing sketch supports sketch blocks. But, it is not something we are looking to support soon. Do you know actually you can reuse AutoCAD blocks within Inventor without having to recreate them? If you start a new drawing using the dwg file as a template, the AutoCAD blocks will be included. You can insert it from the browser panel without having to recreate it.
Many thanks!
Software Test Engineer
Hi Alan,
Many thanks!
