Inventor Forum
Sketch display setting help please
5 REPLIES 5
282 Views, 5 Replies
We recently upgraded to 2019 from 2016, I imported my settings but as per usual jumping that many versions a lot of them did not apply.
It is not a big deal but when I edit a part in an assembly, the parts not being edited would go somewhat transparent in 2016. This does not happen in 2019, what setting am I looking for?
Thanks for any help
5 REPLIES 5
Cadmanto
Under the application options, assembly tab.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2020
Best Regards,
Scott McFadden
(Colossians 3:23-25)
jhackney1972
This should be the setting you are looking for.  Application Options are found under the Tools tab.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
jhackney1972
in reply to: jhackney1972
@Cadmantois correct, my setting is for the "amount" of transparency.  Sorry about that.
John Hackney
Retired
JDMather
If you would prefer a "toggle" you can dock these two buttons anywhere on your ribbon.
Thank you All for your replies.
3 answers that helped me to get it just the way I wanted.
