We recently upgraded to 2019 from 2016, I imported my settings but as per usual jumping that many versions a lot of them did not apply.
It is not a big deal but when I edit a part in an assembly, the parts not being edited would go somewhat transparent in 2016. This does not happen in 2019, what setting am I looking for?
Thanks for any help
Solved by JDMather. Go to Solution.
Solved by jhackney1972. Go to Solution.
Solved by Cadmanto. Go to Solution.
Under the application options, assembly tab.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2020
This should be the setting you are looking for. Application Options are found under the Tools tab.
John Hackney, Retired
If you would prefer a "toggle" you can dock these two buttons anywhere on your ribbon.
