Inventor Forum
Sheetmetal - Flange on a Curved Part Cut-out
14 REPLIES 14
Message 1 of 15
jacquesWVET4
877 Views, 14 Replies
Hi All
Need help please.
In Sheetmetal, ive got a curved plate made with Contour Roll.
In the middle of the plate Ive got a cut-out, on this cut out I need to make a flange.
Has anyone ever done this?
14 REPLIES 14
Message 2 of 15
Attach your files.
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
Message 3 of 15
Hi Kacper
Attached the main file I need help with.
Thanks sooo much
Message 4 of 15
89198826955
in reply to: jacquesWVET4
should it be like this?
Message 5 of 15
jacquesWVET4
in reply to: 89198826955
Hi
Thanks so much for that.
But its the other edge, please see attached.
Message 6 of 15
89198826955
then the algorithm
1 3d sketch - add geometry
2.plot surface
3 thickness
Message 7 of 15
jacquesWVET4
Thanks, but how did you do it?
Will I be able to flat pattern it, Laser Cut and Bend afterwards?
Message 8 of 15
89198826955
unfolding fails
Message 9 of 15
jacquesWVET4
It should work,
Flat Pattern would look something like this.
Message 10 of 15
89198826955
Message 11 of 15
jacquesWVET4
Thank you for the help.
It unfortunately wont work because im not able to create a flat pattern from that.
I am struggling to read your language so it might be my fault. 😀
I have however found a way to do this.
Convert to standard part,
Workplane half way
Manually draw the flange with correct fillet and material thickness
Extrude but leave relief for bend
Convert back to sheetmetal
Hope this makes sense.
Screenshot 2023-07-22 183122.jpgScreenshot 2023-07-22 183237.jpgScreenshot 2023-07-22 183853.jpgScreenshot 2023-07-22 184010.jpgScreenshot 2023-07-22 184047.jpgScreenshot 2023-07-22 184117.jpgScreenshot 2023-07-22 184150.jpgthe flange with correct material thickness and fillets.
Convert back to sheetmetal and it is now able to flat pattern.
Message 12 of 15
Look this:
Kacper Suchomski
Message 13 of 15
SBix26
Your method is good, except there is no need to convert to standard part and then back to sheet metal.  The ordinary modeling tools work as usual in sheet metal parts.  Just use BendRadius for the radius and attach the sketch to the sheet metal edges and all is well.  See @kacper.suchomski 's similar method.
Sam B
Inventor Pro 2024.1 | Windows 10 Home 22H2
Message 14 of 15
Thank you Kacper, this is excellent.
I learned something today.
Really appreciated.
Message 15 of 15
jacquesWVET4
in reply to: SBix26
Thank you SBix26, really appreciated.
