Hi All
Need help please.
In Sheetmetal, ive got a curved plate made with Contour Roll.
In the middle of the plate Ive got a cut-out, on this cut out I need to make a flange.
Has anyone ever done this?
Solved by kacper.suchomski. Go to Solution.
Solved by jacquesWVET4. Go to Solution.
Attach your files.
Kacper Suchomski
Hi Kacper
Attached the main file I need help with.
Thanks sooo much
Hi
Thanks so much for that.
But its the other edge, please see attached.
Thanks again
Thanks, but how did you do it?
Will I be able to flat pattern it, Laser Cut and Bend afterwards?
Thank you for the help.
It unfortunately wont work because im not able to create a flat pattern from that.
I am struggling to read your language so it might be my fault. 😀
I have however found a way to do this.
Convert to standard part,
Workplane half way
Manually draw the flange with correct fillet and material thickness
Extrude but leave relief for bend
Convert back to sheetmetal
Hope this makes sense.
the flange with correct material thickness and fillets.
Convert back to sheetmetal and it is now able to flat pattern.
Look this:
Kacper Suchomski
Your method is good, except there is no need to convert to standard part and then back to sheet metal. The ordinary modeling tools work as usual in sheet metal parts. Just use BendRadius for the radius and attach the sketch to the sheet metal edges and all is well. See @kacper.suchomski 's similar method.
Sam B
Inventor Pro 2024.1 | Windows 10 Home 22H2
Thank you Kacper, this is excellent.
I learned something today.
Really appreciated.
