Inventor Forum
Sheet Metal Part Appearance
4 REPLIES 4
lkirit2000
642 Views, 4 Replies
Hi
I need to apply a color to sheet metal part, but outer surface should be chequered plate appearance. How to do that.
Rgds
4 REPLIES 4
Xun.Zhang
in reply to: lkirit2000
Hi @lkirit2000,
Just select all outer faces and apply the appearance to those faces.
You can refer to below example.
http://autode.sk/2FuJrpd
Hope it helps a little bit.
Xun
kelly.young
Hello @lkirit2000 are you saying that you want the Checker Plate but have it red and not silver, for example?
Have you tried changing the Tint from the Appearance Editor?
Please select the Accept as Solution button if a post solves your issue or answers your question.
mcgyvr
in reply to: kelly.young
@kelly.young Where did you pull red from?
You edit the post or something?
kelly.young
in reply to: mcgyvr
@mcgyvr they just asked for "a" color, arbitrarily chose red as an example is all.
