If you have a "C" channel shape (for example) and drill a THRU hole in one
of the short legs of the "C" so that it goes through the other leg, although
you "see" two individual holes, Inventor only sees a single hole that
happens to go through two faces.
When flattened, the other face is no longer "hit" by the axis of the hole.
A possible reason that you aren't seeing all you should?
Autodesk, Inc
7995 SW Mohawk
Tualatin, OR 97062
503-692-8339
gary.r.smith@autodesk.com
