Is there a way to change the settings on inventor 2023 to have my custom preferences already set when I boot up Inventor. For example upon start up I change the colour and scroll direction among other things but it is becoming a pain to have to do this every time I load the software.
Solved by pcrawley. Go to Solution.
@10783602
Hello and welcome to the forum!
You should be able to set all of these in your Application Options, and they should persist for each new session of Inventor.
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
I agree with @CGBenner - Inventor usually remembers the Application Options between sessions. Occasionally though, your permissions in Windows prevent those settings from saving.
If you configure Inventor the way you like it, then export the Application Options, you can specify that Inventor uses those settings next time you launch it.
See Controlling the Application Options on Inventor Start | Search | Autodesk Knowledge Network
